HELLO'
WHILE TRYING THE DEM RECONDITIONING THIS ERROR CAME UP.
I HAVE TRIED TO CLEAN THE TEMP FOLDER AND SET THE TARGET LOCATION.
CAN SOME ONE HELP?
THANKS
I was just pointing out where that particular error originates from, you will have to determine whether the objected of the inputs was the cause
?do you mean the dem source file?(i don't have that filed either) or do you mean the stream file?
thank you!
An OBJECTID field didn't exist in the source file or wasn't created covers some of the sources where one doesn't exist
Fundamentals of ObjectID fields—Help | ArcGIS for Desktop
Add Incrementing ID Field—Help | ArcGIS for Desktop
thank you,
can you please explain the soulution that is marked correct?
were was the field missing?
Similar thread.
Apart from the solution that is marked correct, there are many other solutions in the following link
Error in DEM Reconditioning in Arc hydro 10
Let us know, if any of the solutions worked for you
