I am attempting to create a Snowflake Database Connection in ArcGIS Pro. I already have the ODBC successfully connected on my computer and am able to connect to snowflake when testing the connection within ODBC Data Source Administrator as well as from within VS Code. When I try to set up the connection in Pro, however, I get "The specified data source (or database) is invalid" when I try to enter anything into the connection propertires for the snowflake database connection. I am able to connect using the "OLE DB Provider" option in pro, but my understanding it has limited capabilities compared to the other approach.
Has anyone encountered this and resolved this?
I am using ArcGIS Pro 3.6.4 and Snowflake odbc 4.2.0.
Edit: I just found this which might address it
https://support.esri.com/en-us/knowledge-base/database-connections-to-snowflake-fail-when-the-snowfla-000044633
. I will update if the instructions work
