Hello, Arcnesia!
Every great mine begins with precise exploration.
However, conventional exploration is costly, time-consuming, and can have a significant environmental impact. Remote sensing analysis—particularly mineral identification using satellite imagery—is an effective way to minimize these risks before field surveys or drilling begin.
Every mineral on Earth's surface has unique spectral characteristics. These characteristics act like spectral fingerprints, allowing scientists and geologists to map minerals using remote sensing. The United States Geological Survey (USGS) has compiled thousands of these fingerprint records in the USGS Spectral Library.
The good news is that NASA has released public data from its first imaging spectrometer (imaging spectrometer) installed on the International Space Station (ISS), EMIT (Earth Surface Mineral Dust Source Investigation). The availability of this open hyperspectral data (open-access) creates significant opportunities to identify the distribution of alteration minerals on Earth's surface in greater detail.
At the recent Geospatial Data Science (GEODETA) 2026 International Conference and the Annual Scientific Forum of the Indonesian Surveyors Association (FIT ISI), I had the opportunity to represent Esri Indonesia and present the results of a study applying Spectral Unmixing to map hydrothermal alteration in the Batu Hijau copper-gold (Cu-Au) porphyry deposit in Sumbawa. This research used native image-processing workflows in ArcGIS Pro through the Linear Spectral Unmixing function.
Spectral Unmixing in ArcGIS Pro
One of the main challenges of satellite imagery in tropical regions like Indonesia is spatial resolution and vegetation cover. At EMIT's pixel resolution (~60 meters), a single surface pixel contains not just one material, but a “mixture” of vegetation, soil, shadow, and various alteration minerals.
Conventional single-pixel classification methods often fail to capture this detail. That's where Linear Spectral Unmixing comes in. This method breaks down each mixed pixel into fractional abundance values for its individual components, also known as endmember.
Using the USGS spectral library and ArcPy scripts in ArcGIS Pro, we performed unmixing in a fully constrained manner across 16 endmember classes. The results were fascinating!
Key Findings & Alteration Zonation at Batu Hijau
Although Batu Hijau is dominated by dense vegetation cover (with average vegetation abundance reaching ~76%), the unmixing workflow in ArcGIS Pro successfully reconstructed a consistent alteration zonation pattern centered on the Batu Hijau pit area:
- Indicator minerals such as actinolite, chlorite, and epidote were successfully mapped, forming a circular halo pattern around the outer area.
- Minerals such as muscovite (sericite), pyrite, and kaolinite were detected in concentrations within the pit's core area.
This study demonstrates that an integrated GIS workflow in ArcGIS Pro can reproducibly process satellite hyperspectral data to identify geological alteration zones.
Applications in the Mining Industry
Of course, processing data in tropical regions with varied terrain offers valuable lessons. In this study, we also identified several spectral side effects that GIS and geology practitioners should be aware of:
- Topographic Shadow Effects: Minerals with flat spectra, such as magnetite, tend to become “catch-all” classes for pixels obscured by hill or terrain shadows.
- Cloud Artifacts: Residual pixels along cloud edges are sometimes misidentified as bright-spectrum minerals such as albite or alunite.
Understanding these data limitations is essential to ensure that the Remote Sensing analyses we produce in ArcGIS remain relevant and geologically accurate.
Overall, this ArcGIS-based spectral mapping workflow is useful not only for improving early-stage exploration efficiency (greenfield exploration), but can also be developed for environmental monitoring throughout the mine lifecycle—from monitoring tailings areas to tracking post-mining revegetation.
On the sidelines of the events, I had the opportunity to engage in lively discussions with several exploration practitioners and professional surveyors. Many of them were enthusiastic to see how the integration of EMIT data into ArcGIS Pro could directly streamline the workflow for determining initial field survey targets. These discussions further emphasised the importance of collaboration between the fields of remote sensing and GIS, and the practical needs of professionals in the field.
Have a similar idea or challenge when processing remote sensing data in your concession area? Let's discuss solutions together in the comments!
