My team conducted surveys using the same form, and now none of us can upload the data from the outbox in the Survey123 app. Is this data gone forever?
It shouldn't be. You can still view submissions in the outbox from the device. Usually, it won't upload if there is a schema mismatch (e.g. changes to the survey were made and the surveys on the devices didn't get updated), bad internet connection (there should be an option to send everything in the outbox if you haven't tried that yet), or if you republished a survey that required a new feature service and your _form view for the survey is still pointing to the original feature service.
This has been 9 years ago since I've done this, but if you go into your device's files survey123 used to store everything in a sql lite database. We were able to copy those when we had a schema mismatch and do a bit of massaging to get the data into the correct format and the correct feature service.
You may end up having to manually type in what you see in the outbox to a new survey or see if you can find the database on your devices that have the data.
Guide here: The Ultimate Guide to Recovering ArcGIS Survey123 Data from Your Phone | Esri Canada
