I'm running into an issue with several referenced layers I have. For some context, these layers are for in field workers to enter data through survey 123 that's embedded in an experience builder. What this combination allows them to do is to receive assignments and then fill out data and complete those assignment meaning there surveys are configured to edit existing data. Recently I've seen this error when I anyone tries to edit an existing record:
This makes it appear that the portal website cannot find the data for the layer being edited. This is confirmed by constant errors in out server error logs when this happens. When it happens it happens for all layers at once.
The error looks like this and confirms for there is an issue reaching the data in the enterprise geodatabase. What could this issue be? Is it losing trust or could it be due to a high number of requests. This has only been happening with the layers that I have hooked up to the experience builder for this specific work flow.
