I'm developing a widget to expert a feature services from an Experience Builder app to DWG.
I wrote a Python toolbox, but the error below is occuring:
line 113, in execute
arcpy.analysis.Clip(
layer,
area_analise,
output_fc
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\__init__.py", line 2782, in wrapped
result = fn(*args, **kwargs)
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\analysis.py", line 202, in Clip
raise e
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\analysis.py", line 198, in Clip
gp.Clip_analysis(*gp_fixargs((in_features, clip_features, out_feature_class, cluster_tolerance), True))
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 541, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000840: The value is not a Feature Layer.
ERROR 000840: The value is not a Scene Layer.
ERROR 000840: The value is not a Building Scene Layer.
ERROR 000840: The value is not a File.
Failed to execute (Clip).
Failed to execute (ExportDWG).
Has anyone made a script like this before? My goal is to use ArcGIS Pro to build custom toolboxes, publish them as geoprocessing services on ArcGIS Enterprise, and use the Analysis widget to load this custom tool.
