We are currently using WindMil Map applying edits to our electric network. We then need to apply the same edits to a matching file geodatabase feature class for each of the layers edited in WindMil Map.
Is there a way to edit in WindMil Map and then push out the edited layer to an ArcGIS Pro file geodatabase so we would not need to perform double editing? I'm using the file geodatabase as an example, thinking that I could just redirect my source file to that location and always get the latest copy from the WindMil export before publishing to ArcGIS Online.
Thank you.
Jeff
