Starting in 3.7. I have copied my KMLs & KMZ into for data folder but I need to know how to open & edit them in ArcGIS Pro.
You can convert a KMZ file to a GIS layer using the KML To Layer Tool in ArcGIS Pro
Pro can natively view KML/Z files, but you can convert with KML to Layer, like @MohammedSubair says
"ArcGIS Pro supports adding KML and KMZ layers to the map in their original format without conversion. However, to perform editing or to modify the layers in any way, the layer must be converted using this tool. You can select the KML layer as the input to this tool."
https://doc.esri.com/en/arcgis-pro/latest/tool-reference/conversion/kml-to-layer.html?tabs=dialog
In ArcGIS Pro 3.7, there is a new KML To Geodatabase (Conversion Tools) | ArcGIS Pro documentation tool that you can use to convert to a geodatabase. It can also output to a shapefile and memory workspace too!
