I have an application with multiple tabs that have the same layout with different maps and data in the tables from an arcade expression. There is a map in the main panel of a side bar widget, with a table in the side panel. My table is set to 'fit to data' for the header and 'wrap text' for the body. I want the columns to show up in full when the application is open, even if they have to scroll sideways to see the rest of the table. They can always expand the side panel further to see the whole table.
However, when i first open the application in the first tab, the table loads with truncated headers, but other tabs show the table how I want it. When I refresh the application on a different tab then the homepage, my column headers are truncated but the other tabs are fine even my home tab which was showing the truncated headers initially. So whatever table gets loaded first, the headers are initially truncated.
Any ideas of why this is happening?
Here are two screenshots to illustrate what I am seeing.
