Describe the bug
One point with 'NaN' coordinates makes spatial.join return 0 rows with no error when arcpy is the geometry engine. full_extent also returns nan. With shapely as the engine, the same data raises an error. ESRI REST Service queries can return 'NaN' in geometries.
To Reproduce
Steps to reproduce the behavior:
import pandas as pd
import numpy as np
from arcgis.features import GeoAccessor
from arcgis.geometry import Point, Polygon
sr = {'wkid': 2868}
# 10 valid points and 1 empty point ('NaN' is how REST services return empty points)
points = [Point({'x': 100 + i, 'y': 100 + i, 'spatialReference': sr}) for i in range(10)]
points.append(Point({'x': 'NaN', 'y': 'NaN', 'spatialReference': sr}))
pts = pd.DataFrame({'ID': range(11), 'SHAPE': points})
pts.spatial.set_geometry('SHAPE')
# One polygon that contains all 10 valid points
box = Polygon({'rings': [[[0, 0], [0, 500], [500, 500], [500, 0], [0, 0]]], 'spatialReference': sr})
polys = pd.DataFrame({'PID': [1], 'SHAPE': [box]})
polys.spatial.set_geometry('SHAPE')
# Print spatial join with NaN points
print('Silent error: 0 joins')
print(pts.spatial.full_extent)
print(len(polys.spatial.join(pts, how='inner', op='intersects'))) # expected 10
# Remove NaN points
is_valid = pts['SHAPE'].apply(lambda g: np.isfinite(np.array([g['x'], g['y']], dtype=float)).all())
pts = pts[is_valid].reset_index(drop=True)
# Print spatial join with NaN points removed
print('Joins successful')
error:
(nan, nan, nan, nan)
Joins successful
(100.0, 100.0, 109.0, 109.0)
10
Expected behavior
arcgis engine should ignore the 'NaN' geometries and complete the join or should provide an error like shapely does letting the user know the cause of the failed join.
Platform (please complete the following information):
- OS: Windows
- Chrome
- arcgis 2.4.2, arcpy 3.6.1, shapely 2.1.2
Additional context
shapely engine error on the same spatial.join: shapely.errors.GEOSException: UnsupportedOperationException:
