Hi all!
We have a GNSS receiver connected to a field laptop via RS-232, and we need to feed its NMEA data into ArcGIS Pro running on the same machine.
The issue is that the receiver's vendor software needs to keep the COM port open to log raw data. As soon as it does, ArcGIS Pro can't access the port and reports that it's already in use.
We also have a second use case: a processing station in the vehicle needs to receive the same GPS/IMU data stream over the network, as running a second physical cable isn't practical.
Is there a reliable way to share a single physical serial port between multiple applications or machines without running into COM port conflicts? Ideally, we're looking for a solution that doesn't require special firmware and works reliably on 64-bit Windows.
Thanks!
