I have a feature layer that was published to AGOL without any metadata (from Pro). Once it was in AGOL, I used the Item Details Assistant to generate metadata for the layer. However, when I add that feature layer back to ArcGIS Pro and I go to view metadata, there is nothing there. Any ideas what is going on?
The full information seems to flash for a second as it is loading and then it returns to the empty template. I can see the full info in the catalog view when directly accessing the Portal item, but as soon as I bring it into the local environment it's gone. I have tried refreshing/syncing/etc. and no luck. TIA!
