I'm trying to create a map in ArcGIS Pro with a mix of WGS84 and TA83 data.
When I try to publish it into a webmap, Pro doesn't like that - not to mention, Field Maps defaults to WGS84(?).
A key piece of data I'm working with are buffers, ranging from 0.5 miles to 5 miles.
I understand calculating in PLANAR with TA83 would be ideal, but if the end product is WGS84, would calculating in GEODESIC with WGS84 make the most sense?
Please help, thank you!
