Hello everyone,
we are currently trying to define a practical workflow for handling File Geodatabases in project environments where data is shared through OneDrive, SharePoint/Teams, Autodesk Docs, Autodesk Desktop Connector and sometimes Autodesk Forma-related workflows.
I’m aware that working directly with a FileGDB inside a synchronized folder is not a good idea. Since a FileGDB is a folder with many internal files, I want to avoid users editing or processing it directly from OneDrive, SharePoint sync or Desktop Connector locations.
What I’m looking for is how others handle this in practice.
For example:
- Do you always zip the complete .gdb folder before sharing it?
- Do you use a local working folder and only upload/sync the result afterwards?
- Do you have scripts that check for lock files, compact the GDB and create a ZIP archive?
- How do you manage naming, versioning or archiving of FileGDB packages?
- Have you run into specific problems with OneDrive, SharePoint, Autodesk Docs or Desktop Connector?
- Have you moved away from FileGDBs in these workflows and used something else instead?
Our goal is to give users a simple and safe internal process. Something like:
- copy/download the FileGDB locally
- work on it in ArcGIS Pro
- close ArcGIS Pro / release locks
- package the complete .gdb as ZIP
- upload/share/archive the ZIP through SharePoint, OneDrive, Autodesk Docs or another platform
I’d be very interested in real-world examples, small automation ideas, lessons learned or patterns that worked well for your teams.
Thanks!
