Some of the ArcGIS Pro tools like TIN to Multipatch and Interpolate Polygon To Multipatch and likely others appear to fail and give this error message if the output z values are less than -100000. It appears that the default Zmin is -100000 and Zmax is 900719825474.099 when one creates a new feature class in a FGDB.
I assume that this is the default Zmin is and Zmax for rasters and the output limitation from some of the Pro GP tools. As a test when I ensure that that input raster (before running Raster to TIN) z values are greater than -100000, these two tools work fine.
Had a likely similar issue with the Zmin is -100000 issue with the Raster to TIN tool and Extrude Between tools 1.5 years ago. ESRI logged this as a bug.
I have tried changing the Output Z Domain in Pro Min Z to be much less than -100000 so it is less than the z values of my raster data and the tool still fails: Analysis>Environments>Z Values> Output Z Domain. I have tried changing this: Output Z Domain (Environment setting)
https://pro.arcgis.com/en/pro-app/3.4/tool-reference/environment-settings/output-z-domain.htm
and it still fails. I have changed the Output Z Domain Min Z under Environments before attempting to run the Polygon To Multipatch tool and it still fails.
I need a Output Z Domain Min Z of much less less than -100000 for in order to burn in a vertical exaggeration into my raster surfaces in order to able to use them in AGOl Scene Viewer. Any suggestion or work arounds would be a great.
