With the release of ArcGIS API for Python 2.4.4, we want to extend a huge thank you to our community. Your feedback and active participation are what truly shape the evolution of this product.
For those new to the ecosystem, our public GitHub repository is your go-to hub for samples, tutorials, and documentation. Your feedback through Technical Support and our public repository are where your voice matters most—we actively monitor the issues and enhancement requests logged there, integrating your ideas into every release cycle.
Here are a few of the submissions from internal users and community members that made it into the 2.4.4 release from both the public repository and through your Tech Support feedback.
Bug Fixes:
- BUG-000187420 Query Distinct Values hangs when OID field is not ObjectID
- BUG-000183141 Printing a webmap in ArcGIS Online using web_map.print() fails to create layers from external tile services
- [BUG] The FeatureLayer.query_top_features operation does not support the
return_count_only parameter - Item.update() failing to update item properties to empty strings
- On Kubernetes, notebook job result can remain stuck at "cancelling" after backend reaches "cancelled"
- Cannot move items to "Root Folder" with version 2.4.3
- Folder.add with stream=False raises UnboundLocalError for "calculate_upload_size"
- Missing/Incorrect parameters for two raster analytics functions tools
- None returned as credit estimate value for some feature analysis methods.
- TypeError: _FeatureAnalysisTools.enrich_layer() got an unexpected keyword argument
'travel_direction' while running enrich_layer() tool - The DeveloperCredentials.generate_token call removes primary key when
generating a secondary one - Folder.add() causing possible
memory leak and getting killed - FeatureLayerCollection
insert_layer() only works if there are no tables present in the Feature
Service - dry_run for item.delete() on
a "Code Attachment" fails unexpectedly with TypeError exception - FeatureLayer
get_unique_value() returns duplicates (2.4.3) - Cannot move items to
Enhancements:
- [ENHANCEMENT] zoom_to_layer() for Map or Scene can accept Item or index of map content items as input
- [ENHANCEMENT] Utilize baseurl when making Survey123 API requests
- [ENHANCEMENT] Offline Clone Manager catch-all workflow for generic text and file-based items
- [ENHANCEMENT] Add Map Showcase Item type
- [ENHANCEMENT] DataFrame option for query/search results
- ENH-000183856 [Enhancement] Add 2D Web Sketch Style Group starting Enterpise 11.5
- [ENHANCEMENT] Add upgrade_survey() method to Survey class for migrating to next generation Survey123
