Hi all,
Has anyone seen ArcGIS Pro create folders in unexpected locations simply from opening an APRX?
In one recent example, a folder suddenly appeared, including files, (called 'GIS Folder migration - see screenshots below) - as soon as I opened an aprx located in the Projects folder.
The strange part is that "GIS Folder migration" is the name of a higher-level workspace elsewhere in the directory structure. No ArcPy scripts, notebooks, models or automation were running at the time, just normal use of ArcGIS Pro and Catalog.
Most of these projects originated in SharePoint/OneDrive environments before being copied to local storage, so I'm wondering whether this could be related to stale folder connections, relative paths, cached metadata, or other issues.
In another mysterious example, when viewing in Catalogue, I occasionally see incorrect folders appear in the view, eg - this screenshot below, the Sites folder doesnt actually exist (you may notice in the path is should actually be called 'ForBDR'
Has anyone encountered similar behaviour or found a root cause? We have recognised OneDrive is flakey, and plan to move away from this environment. However, if we continue to see 'hangover' issues even after moving from OneDrive, that is particularly concerning. We have 100s of project folders / existing aprxs, so my fingers crossed we can find a way to resolve.
Thanks.
