I post on my first about Task because I am learning how to use . I am behind than most of you are probably to the newer ArcGIS Pro. I am currently using 3.5.6 through VDI system.
I add one step that I am doing a lot of clipping on a lot of layers to set specific layer. The only problem I have trouble is Output Feature class to %Name%_clip because it is from the Model Builder and it uses it. I am wondering if there is something or a way around to substitute for that on the Tasks ?
Type of Command Geoprocessing tool and then hit the Edit button.
Here it is the screenshot of what I did.
Thanks !!!
