The pie chart configuration in ArcGIS Dashboards is incredibly frustrating from a design standpoint.
The biggest issue is that the size of the pie chart itself is essentially controlled by the surrounding element and by whether labels/legends are enabled. However, changing the labels or legend does not give me meaningful control over the actual size of the pie chart. The chart can remain surprisingly small while leaving a huge amount of unused space around it.
If I want the pie chart to be larger, my only real option is to make the entire Dashboard element larger. I should not have to make an element unnecessarily huge just to get the chart itself to display at an appropriate size.
This creates dashboards that look awkward and poorly balanced. I can end up with a relatively small pie chart sitting in a large amount of empty space simply because the chart does not provide enough control over how it uses the available area.
What I would like to see
Please add an option to control the size of the pie chart independently from the Dashboard element, such as:
- A manual chart size setting (percentage, pixels, etc.)
- Separate horizontal and vertical sizing controls
- An option to have the chart automatically stretch to use the available height/width
- The ability to position the chart within the element independently of the legend/labels
Essentially, if I make an element 500px tall, I should be able to tell the pie chart, "Use 90% of the available space" rather than having Dashboards decide how large the pie should be based on labels, legends, and other formatting.
I realize that labels and legends need room, but the current behavior makes basic dashboard design unnecessarily difficult. There should be a clear distinction between the size of the Dashboard element and the size of the chart inside that element.
There is already an Esri Community discussion about the excessive empty space around pie charts (Pie Chart Formatting Limitations - Excessive Element Border/Background Space), and the existing Idea addressing this issue is still open. The workaround of adjusting label offsets can help in some situations, but having to manipulate label offsets just to change the apparent size of the pie chart is not an intuitive or sustainable solution.
