We are about to upgrade our image servers from 11.3 to 11.5. In that work we have detected, for us, a major problem. That upgrade involves involves upgrading ArcGIS Pro also.
Our workflow is adding rasters to a mosaic dataset and then publish the mosaic datasets.
What we have found is that we are not able to add MRF files that has a "scientific"-notation on the bounding box. But if we change the notation to "float" the files works fine.
MRF files with scientific notation worked fine in 11.3 and in ArcGIS Pro 3.3.2
But when we upgrade servers to 11.5 and ArcGIS 3.5 problems occurs.
Do not work: <BoundingBox minx="700000" miny="6.4e+06" maxx="702500" maxy="6.4025e+06" />
Works: <BoundingBox minx="700000.00000000" miny="6400000.00000000" maxx="702500.00000000" maxy="6402500.00000000" />
For mosaics that are already created and just published the following to endpoints does not return anything:
/exportimage
/computeHistograms
but the following two works
/computeHistograms
/query
We think that a change in reading metadata from the BoundingBox tag has changed in Pro and on the server side.
Any other organizations that has similar issues when upgrading to 1.5? Or suggestions how to proceed.
Best regards,
Simon Johansson
Swedish Forest Agency
