We are trying to clean up our data. Is there a way in parcel fabric to mass check data layers for gaps and overlaps of parcel and lots etc. In branch versioning that is relatively simple to do.
Thanks for any assistance and advice you can give.
I don't use parcel fabric but I found in ArcPro 3.5 and newer there is a vertices and nodes tool that does highlight when polygons/lines don't connect when the program thinks it should. Helps me visually see where and how to clean my data up. https://pro.arcgis.com/en/pro-app/3.5/help/editing/symbolize-vertices-and-nodes.htm
@joshua .001, have you checked out our Highlight Gaps and Overlaps geoprocessing tool?
Is your goal to simply identify and highlight the gaps and overlaps, or are you looking to fix the underlying issues as well?
The GP tool will highlight the problem areas, and you can then use the Parcel Fabric editing tools to correct them.
we were trying to see if there is a way mass search for errors that wouldn't interfere with branch versioning and the enterprise system. that cans be seen by all our members so that way when we have any extra time, we can correct them. thanks for all your assistance.
That is interesting info. I appreciate the help.
Anyone should be able to use it and you can turn it on/off just by clicking the button at the bottom of your map.
