Hi all,
I have a couple of questions about the Chapter 4 exercises.
1. Missing starting template
I couldn't locate the starting template "Wildfire In North America" (owner: Top20EssentialSkillsForExperienceBuilder) — searching for it in AGOL doesn't return any results. Has it been renamed, moved, or removed since the book was published?
I found what looks like the same template here:
https://experience.arcgis.com/experience/78608cd3dce84203b8bbe3a4fbb92de2
I've done my best to recreate it based on that:
https://experience.arcgis.com/experience/eddb0e2c8bf0421793ee0eb3ffd360b7
If anyone can confirm whether this is the correct/official template, I'd appreciate it.
2. Workflow summary step (p.69)
Step 4 of the workflow summary says to "link the text to the appropriate pages," but the walkthrough only covers adding links to the images, not the text/titles. I eventually figured out how to add links to the titles instead, but wanted to check whether I missed a step or whether this is a gap in the instructions.
Is there a known errata list for the book? I ran into a similar problem in Chapter 1, where AGOL could only find the starting item if you searched by owner — that requirement wasn't mentioned in the textbook, but I found the fix by searching this forum. Wondering if there's a central place these are tracked, or if it's mostly a matter of searching the board as issues come up.
Thanks in advance for any pointers. I hope this post doesn't come across as whiny (definitely not the intention). I'm just new to Experience Builder, so some of this is a little frustrating when trying to follow the guides in each chapter..
