Hi everyone,
I have two Utility Networks, one for water, one for sewer. They're completely independent: each one lives in its own enterprise geodatabase and is published as its own web feature layer on the same federated server. What I'm trying to build is a single web map that shows both networks together, plus a few shared reference layers. Every time I share that web map it fails at the very end with Failed to add web item.
What convinced me that the issue it's the two-networks combo and not something else is this:
- Water UN only (sewer removed): publishes fine.
- Sewer UN only (water removed): publishes fine.
- Both in the same map: always fails.
So, a few questions:
- Is it a real limitation that a web map can only reference one utility network at a time?
- If it is, is there anything official that states it, so I can point to it?
- What's the recommended way to give users a single, unified view over both networks — two separate web maps combined at the app level?
Environment: ArcGIS Pro 3.7, ArcGIS Enterprise 11.5.0, Utility Network version 7.
Thanks in advance.
