The Calculate Field toolbar in ArcGIS Pro attribute tables lets users calculate field values directly from the table view.
Currently, after opening an attribute table, users can click Calculate to display the Calculate Field toolbar. However, if the attribute table is closed and opened again, the toolbar does not remain visible. The user has to click Calculate again each time.
It would be helpful if ArcGIS Pro had an option to keep the Calculate Field toolbar open, or automatically reopen it when an attribute table is opened again.
For example, this could potentially be handled as a global setting in ArcGIS Pro Options, a table view preference, or another application-wide preference.
In my workflow, I often perform repeated field calculations while reviewing and updating attribute data, so having the toolbar remain visible would make the process smoother and reduce repeated clicks.
This would be useful for workflows where users perform repeated field calculations across one or more attribute tables. It would also make the Calculate Field toolbar feel more consistent with other table-based workflows in ArcGIS Pro.
The current Calculate Field toolbar capability is described in this Esri article:
https://www.esri.com/arcgis-blog/products/arcgis-pro/analytics/calculate-field-toolbar-arcgis-pro
