Welcome to the troubleshooting guide for ArcGIS GeoBIM UI errors. While many interface messages are straightforward, some may require extra guidance to workaround or resolve.
Use the information below to troubleshoot the common UI errors experienced within ArcGIS GeoBIM.
In order to avoid any Fail to load errors you must follow the steps in upgrade a GeoBIM project and app.
Once completed, the GeoBIM project and app will be fully updated to the latest supported version of Experience Builder.
Ensure you selected the correct datasource on the Links page.
Ensure the Link Rule configuration is using the correct fields and that your data contains the necessary information to define a valid link.
See add links to features using rules to learn more about configuring links by attribute data.
This message displays in the Issue Charts widget if:
To workaround the No data found message:
The Time Slider widget indicates that the selected layer does not contain temporal data.
The Elevation Profile widget indicates that there are no selectable polyline features in the area of the map that was selected.
If there is a polyline in the area you selected, ensure the layer is enabled in the Elevation Profile widget.
If you encountered a UI error in ArcGIS GeoBIM that is not listed in the table above and you are unsure on next steps, please leave a comment under this article and the ArcGIS GeoBIM team will respond with recommended actions as soon as possible.
