Hi @aymanatia! Based on the screenshots provided, it looks like you are on the right track here. I am curious what behavior you see after you click "OK" in the "Paste" dialog box when the target layer is selected? Are the features from your first layer not showing up in the target layer as expected? What version of ArcGIS Pro are you using?
In ArcGIS Pro 3.6.2, I used the following workflow to copy and paste features from one layer to another:
I created LineLayer1 with one line feature.
I created LineLayer2 with two line features.
I turned the visibility of both layers on and then selected the two line features from LineLayer2. I right clicked and selected "Copy" to copy the features.
I clicked the feature in LineLayer1, then right-clicked and chose "Paste Special."
Since we are pasting the layers from LineLayer2 into LineLayer1, I left LineLayer1 as the target layer in the Paste Special dialog and clicked "OK."
After clicking "OK" on the Paste Special dialog, the two new copied features were added to LineLayer1 as expected.
Please let me know if you have success with the workflow outlined here or if you run into any additional questions.
I hope you have a nice day!
Emma
Hi @Emma65 , Thank you Very Much, I Found a solution to my question on your reply, I am work on Arc pro. v 3.4.2 , I found the (Paste Special) tool in the menu of Edit.
Once again, I express my sincere thanks for your attention.
Hi @Emma65 , I have another question Please,
I want Extract AOI from any image in arc pro. by the method of (drawing a rectangle on image> R. ck on image layer> Data> Export data) As well as in Arc map 10.8.
I want a brief method instead of traditional step (Extract by mask).
Sign in to post, follow content, and more. New here? Register for free.
