In Roads & Highways, we would like to have Experience Builder set up with Add Point Event --'Coordinate method' with option to capture coordinates from Map click point. Not sure if this can be done by using widgets in experience builder. This functionality existed in "event editor" as Adding point events by coordinate location—ArcGIS Roads and Highways Server | Documentation for ArcGIS Enterprise
We are at Enterprise v12.1
If anyone has set this up successfully in experience Builder, or have ideas how to do it, appreciate any help.
Thanks!
Hi Elsit, if you're using the map to create a new point event, you can just utilize the Route and Measure method. If you're trying to get the coordinates at the location by clicking the map, you should look at utilizing the Coordinates Widget https://doc.arcgis.com/en/experience-builder/latest/configure-widgets/coordinates-widget.htm.
Update: Our team tried to do based on documentation above, but wasn't able to. Now it is an enhancement request: ENH-000186692.
Also related, there is experience builder widget idea:
Capturing lat/long and passing them to the Add Poi... - Esri Community
