Hi there.
I created a dropdown list question in my Survey123 form, but when I try to migrate or add the same list to the Field Maps Designer, the dropdown values do not appear. Instead, I receive the error message "one or more properties are invalid". Is this a known issue, and is there a workaround to get the dropdown list to display correctly in Fields Map Designer?
Thank you.
Can you provide some additional details on the method you used to migrate / add the dropdown in Field Maps Designer? The error message showing is because you have an empty list of values for the dropdown list, see the Edit List (0) button in your screen shot.
