Overview
GitHub: https://github.com/brianmcleer/add-edit-etl-widget
Add, Map & Edit Data is a customized widget that combines two of Esri's out of the box widgets, Add Data and Edit, and drops a field-mapping step in between them. It came out of a recurring headache I kept running into. Someone has a spreadsheet or a layer they want to get into an existing editable layer, but the incoming field names never line up with the target, so the data has to be reshaped outside Experience Builder before anyone can edit it. I wanted the whole thing, add, map, load, and edit, to happen in one widget without
