Currently, when working with heavily managed Utility Network (UN) datasets, enterprise administrators cannot scale or automate map production using Python scripts. Subtype Group Layer sublayers isolate their rendering pipeline from the standard ArcPy/CIM environment.
When attempting to programmatic change symbols on a Subtype Feature Layer using standard workflows (e.g., layer.symbology or low-level layer.getDefinition('V3')), the application either silently drops the edits, throws an attribute error, or corrupts the internal XML schema validation, throwing a "Requested operation could not be completed" banner and rendering a blank white square in the UI.
Even using CIMREGISTRY pointers on dynamically generated CIMUniqueValueClass entries fails because the UI-cached values are hidden from the active layer definition matrix until manually committed via mouse clicks in the Symbology pane.
Proposed Solution / API Extension
Extend the ArcGIS Pro arcpy.mp or arcpy.cim module to natively support schema-aware unique value mapping on Utility Network sublayers. Specifically:
Provide a stable high-level method such as UniqueValueRenderer.addValueCombination([field1, field2], style_item_name) that forces serialization straight into the core map document.
Allow Symbol.applyStyleItem() or an equivalent property-setter to interact with read-only subtype symbol objects when a valid style sheet is actively imported into the project items framework.
