PSA in case this helps others prevent data loss:
There is a bug related to the image back button in Survey123 that resulted in costly data loss during our 2025 field season. ESRI confirmed the bug but stated that they do not intend to fix it because they are focusing on their next generation build of Survey123. In prep for the field season this summer, we tested on our new Samsung Galaxy Tab Active 5 tablets using the latest version of Survey123. We were able to reproduce the bug. We have also replicated this bug on iPhones, iPads as well as the desktop version of Survey123 for Windows. ESRI was able to replicate this bug using their own survey template published to ArcGIS Online, which ruled out any issues on our end. Regarding affected versions, we first noticed the bug with version 3.22.53. We have replicated it in all subsequent versions as well. We had 4 data loss incidents last summer caused by this bug. It was our 5th season using Survey123 and we had not encountered the bug before, which leads us to think it was introduced in late 2024 or early 2025.
Below is a guide we sent to our crews to educate them on what triggers the bug and steps to take to recover a survey. I hope others find this information helpful!
Actions that trigger the bug
- When taking a photo, there is a back button (see image below). Intermittently, when tapping/clicking the back button, survey123 goes back too many levels and exits the survey without prompting the user to save the survey as a draft. The bug appears to be triggered by the user inadvertently tapping the back button more than once, but we may have had cases where a single tap triggered it.
- Viewing a photo that has already been taken and tapping the back button to return to the survey has also triggered the bug.
- Opening an image added to the survey using the media::image column to view it in full screen mode and then tapping the back button has also triggered the bug.
How to recover your survey if you encounter this bug
- Do not try opening the survey again from the Inbox if you are using Inbox. Do not use Collect to start a new survey. Doing so will delete the backup file containing your survey data.
- Instead, go to the device’s open applications window and swipe to close Survey123.
- Reopen Survey123. Upon reopening, you should see a “Recovered Survey” dialog. At the bottom, tap Continue survey
Recommendations for minimizing the possibility of triggering this bug
- If you tap the option to take a photo and then decide a new photo is not needed, do not tap the back button to return to the survey. Instead, take the photo, and then delete it after the device returns to the survey.
- Don’t tap on an embedded survey image to open it in full screen mode.
- Avoid viewing photos unless necessary.
Additional recommendations for safeguarding your data
- Save the survey to draft periodically.
- Tap the X button in the upper left corner, then select the Save in Drafts option
- This closes the survey and you will then need to open it again from the drafts folder. Survey123 does not have an option to save the survey while keeping it open, unfortunately.
- Take a screenshot of data that cannot easily be collected again before taking or viewing a photo
