Hello, i have no idea what is going wrong when I try to add a rule to the utility network. I have editing turned off for all layers, so I know that's not the case. There are no other editors editing the data also. Any advice? thanks George.
This article provides a very good overview of performing schema changes and how locks effect them from Map Services. You'll just have to pick Windows/Linux and what version of Enterprise you are on.
https://enterprise.arcgis.com/en/server/latest/administer/linux/disabling-schema-locking-on-a-map-service.htm
where do I find that? I'm relatively new to this.
If you have this checked on under parameters for any services even with map service only enabled it will probably cause a schema lock.
no -other than maps and apps in AGOL and portal.
Yes, but it's directly pulling from a geodatabase. It's not officially published as a service.
thanks George
If this is a network that you have "up and running", you have likely published it as a service so that you can access and edit it through the feature service. If this feature service is running, you won't be able to add or update any attribute rules until the service is suspended. Stop the service in Server Manager while you perform the update. You can manually break the locks to enable a quick change, but if you have active services, they will reacquire quickly.
Hello @GeorgeJonesRIGOV, do you have a service published that locks the database schema enabled?
Is this in an ArcGIS Enterprise environment? If so, services place schema locks on the dataset so you'll need to turn off the corresponding services (or disable schema locking and remember to restart the services after making changes).
More info: Utility network management tasks—ArcGIS Pro | Documentation
