Hello, I can't run the project after installing the plugin.When I run the project, I get this window and even if I click yes, another window pops up and no matter what I click there, my project simply won’t start.Version of EU - 5.5.4Version of SDK - 2.2.0
Pls help me, i don't know what to do....
That dialog is expected, depending on what version of Unreal Engine you are using. But once built, then you should be able to use the SDK in your project, explore the sample content, etc.
When you say your project won't start, can you provide more detail about what's happening?
@MichaelBranscomb when we download arcGIS SDK and added plugin in project folder, the project itself showing that error and closing the project.even i tired both version of unreal 5.7 and 5.6 with arcGIS 2.2 SDK but nothing works. still getting same error message with Unreal Engine 5.7 and 5.6.Please Help..Thanks
Does your machine meet the system requirements? (System requirements for 2.2.0 | ArcGIS Maps SDK for Unreal Engine | Esri Developer)
What are the format settings on your system (e.g., decimal symbol)?
yes,i have updated window and machine is sufficient to handle.and format settings on my system is "." (full stop)
In Visual Studio, what does the Unreal Engine Integration Configuration dialog show?
Configure Visual Studio Tools for Unreal Engine | Microsoft Learn
