Hi all, a coworker shared a map as a map layer package and the map is currently stuck. He's done it a bunch of times before, but i think it's due to the new install. Wondering what's going on or how to fix it. any advice? thanks!
Was the shortcut used from the ribbon?
Share a map package—ArcGIS Pro | Documentation
or the more controlled tool?
Package Map (Data Management)—ArcGIS Pro | Documentation
Did the analyze step get reached if using the first?
All the data were in a common coordinate system? Extents limited ?
Sharing just inside, or outside your organization?
Since you mention install, perhaps these may have to be tried
Perform an ArcGIS pro Soft Reset
Perform a Clean Uninstall and Reinstall of ArcGIS Pro
or see if someone else can package the map
or Tech Support... they may have more suggestions
