Utility and Pipeline Data Model 2026 is Released
By Tom DeWitte and Tom Coolidge
Esri's Utility and Pipeline Data Model (UPDM) 2026 is available now. This release continues Esri's practice of maintaining a template data model ready "out-of-the-box" to manage gas and hazardous liquid pipe system data within an Esri geodatabase. This release includes enhancements to keep up with industry practice changes and to address feedback from implementations received since the previous release.
Updates to Industry Barcode Standard
Every year, the Plastic Pipe Institute (PPI) adds newly registered manufacturers to the list of manufacturers in the ASTM F2897 barcode standard. F2897 is the Tracking and Traceability encoding system defining the format of the barcode that manufacturers place on their pipe, fittings, valves, and other assets.
For 2026, PPI added the following manufacturers to the standard:
-Hubbell-Lyall
-Flying W Plastics
-Tex-Trude Pipe
-Sovereign Pipe Technologies LLC
-Cosmoind USA, Inc
-Norton McMurray Manufacturing Co
-Alexander Tubular
-Gasoductos Y Estaciones Del Norte (GENSA)
-Do It American MFG Company LLC
-TECO S.R.L.
These additions have been baked into UPDM 2026 to continue its support of this important industry standard.
Compliance with the DIRT
At the IMGIS 2025 UPDM User Group meeting, the community asked that UPDM be compliant with the reporting needs for the Common Ground Alliance (CGA) Damage Information Reporting Tool (DIRT). DIRT is the underground utility reporting tool for tracking damage to buried infrastructure.
To simplify the ability for a natural gas or hazardous liquid organization to submit their instances of damage, we rewrote the excavation damage featureclass in UPDM (P_ExcavationDamage). This extensive rewrite of the excavation damage featureclass will eliminate the need for GIS Professionals to translate their excavation damage field reports for submittal to DIRT. The DIRT required fields will be easy for any administrator, GIS professional, or end user to understand. All DIRT data fields will have an alias that begins with a prefix of DIRT.
Cathodic Protection Data Management
Customers also asked that we enhance UPDM to apply a geospatial approach to cathodic protection (CP) data management. The goal of these enhancements to UPDM is to simplify the often complex, redundant data management practices used by many organizations today.
With this release of UPDM 2026, UPDM consolidates compliance date management and inspections with the mapping process. For example, the mapping process placement of a new CP Test Station will automatically calculate the compliance dates for when the next test station readings are due. This significant enhancement and automation are achieved through attribute rules applied to the PipelineDevice featureclass.
Similarly, when a user submits an inspection for a test station (P_CPTestPointReading) or rectifier (P_CPRectifierInspections) to ArcGIS, attribute rules automatically update the inspected asset's Last Inspection Date. Updating the Last Inspection Date on the PipelineDevice asset will trigger the previously mentioned attribute rules to automatically update the next inspection date and next compliance date data fields. This enhancement provides a fully automated compliance date management capability.
Knowing that compliance inspection cycles vary around the globe, the ability to define the inspection intervals is implemented simply. With UPDM 2026, syncing to a region's regulatory compliance inspection intervals is as easy as populating the newly added data fields: inspectioninterval, and complianceinterval.
Adding a default value setting to these fields will automate compliance intervals without having to modify the underlying attribute rules.
Improving Performance
Esri routinely internally tests UPDM to improve performance. This is a significant benefit for UPDM users! For this release of UPDM', the Esri development team identified a reconfiguration of the asset's life-cycle status to improve Utility Network trace performance. The pre-existing data field, lifecyclestatus, is renamed to assetlifecyclestatus to better reflect its purpose. Added is a new attribute rule-managed data field named assetstate. This new data field is automatically populated and updated as users modify the assetlifecyclestatus data field.
Gas and Pipeline Referencing Utility Network Foundation
For many gas utility and hazardous liquid pipeline enterprises, deploying ArcGIS is more than simply loading the UPDM 2026 data model into an enterprise geodatabase. That's because ArcGIS leverages the concepts of a service-oriented web GIS. It requires additional steps, such as creating an ArcGIS Pro map configured for publishing the data model, publishing the Pro map to create the required map and feature services, and, perhaps, configuring a location referencing system. To simplify these additional steps in UPDM 2026, Esri has embedded it into the Gas and Pipeline Referencing Utility Network Foundation. This solution provides UPDM 2026, sample data, and an ArcGIS Pro project configured with performance-optimized maps.
You can access this solution from the Esri ArcGIS for Gas solution site.
A full data dictionary of UPDM 2026 is available online.
Release notes, documenting the lineage of changes to UPDM over its releases, are also available online.
Esri's Template Data Model for the Industry
Esri first released UPDM in 2015 as part of a new vision for a geospatial system of record for pipe systems that is much more than a departmental solution. It can be a foundational enterprise system that provides a unified office and mobile workforce with a near-real-time single source of truth.
This belief that there should be a single source of truth from which the entire organization can view, query, create, and maintain its entire pipe network has driven not only the development of this industry data model but also our network management and linear referencing capabilities.
This freely available data model takes full advantage of geodatabase capabilities. The data model is created and tested with ArcGIS products to ensure that it works. This significantly reduces the complexity, time, and cost to implement a spatially enabled hazardous liquid or gas pipe system data repository.
Looking ahead to the Future
A wise man once said, "Change is the only constant." This is a great quote to keep in mind as we think about UPDM as we advance. The Esri development team will continue to enhance ArcGIS. Industry will continue to evolve its practices. To continue adjusting to industry practices and incorporating new ArcGIS capabilities, UPDM will continue to evolve. This evolution will help ensure that gas utilities and hazardous liquid pipeline operators have an industry-specific GIS data model that meets their needs.
PLEASE NOTE: The postings on this site are our own and don't necessarily represent Esri's position, strategies, or opinions.
