We use Emlid RX antennas, with RTK corrections to collect data in Field Maps. Using a Map with a NAD83 2011 Stateplane coordinate system, to project on the fly. The issue I am having is when projecting to Northing Easting survey feet, in ArcGIS Pro, the data is off anywhere from one to three feet. I've tried different maps and different coordinate system profiles in Field Maps but it all shows the same bust in the Northing and Easting. I've been testing against known control points using the Lat/Lon from the same data in other Projection tools and those project correctly. What am I missing here?
