Summary:
Enable snapping to feature edges in addition to vertices to improve editing and measurement workflows.
Details:
Current snapping behavior is limited to vertices, requiring users to densify geometries to achieve acceptable accuracy. This introduces unnecessary complexity, increases maintenance, and can degrade performance. Supporting edge-based snapping would streamline workflows and reduce the need for excessive vertex creation.
Use Case:
Measuring perpendicular distance from a centerline point to a water line using the Measure Distance tool. Existing functionality only snaps to endpoints and vertices, limiting accuracy without modifying geometry.
Benefits:
-Improves editing efficiency
-Reduces geometry complexity
-Enhances measurement accuracy
-Supports cleaner, more maintainable datasets
I've logged the enhancement and hope you'll consider ENH-000168338. Cheers!
