I have a spreadsheet to table operation that will need to be done daily. Is there a way to create an automation? I am hoping that the joins will still remain intact. It is a weather update that will affect how settings will be set for sensitivity.
I would need ArcPRO, to retrieve the Spreadsheet from a shared folder online, replace the current sheet.. then if possible, export a Layout(s) to the same shared folder.
The Spreadsheet will have the same name each day...
The layout will show geographically how each area is expected to be affected. Because it is weather, those setting will change from the predicted forecast based on variation in actual weather.
