What is ArcGIS Topographic Mapping?
ArcGIS Topographic Mapping is a production-focused extension for ArcGIS Pro and ArcGIS Enterprise that standardizes and automates end-to-end topographic data and map production workflows, from data capture to enterprise cartography to generating multiscale outputs.
Who is ArcGIS Topographic Mapping designed for?
It is designed for national, civilian, and defense mapping agencies, authoritative data producers, and contractors that need to produce, maintain, and share topographic data and cartographic products at scale using standardized production workflows. These products typically need to comply with industry standards such as Topographic Data Store (TDS), Multinational Geospatial Co-production Program (MGCP), Civilian Topographic Map (CTM), and more.
What problems does ArcGIS Topographic Mapping solve?
ArcGIS Topographic Mapping addresses inconsistent data capture, manual cartographic finishing, and difficult-to-scale generalization by standardizing and automating topographic data and cartographic production workflows. It helps organizations replace ad-hoc, manually-intensive processes with repeatable, specification-driven, automation-focused enterprise-level production systems.
What are some of the benefits of implementing ArcGIS Topographic Mapping?
ArcGIS Topographic Mapping:
- Reduces production time and effort by automating processes.
- Enables delivery of trusted topographic products more efficiently at scale.
- Prevents loss of institutional knowledge that traditionally live in an expert’s mind by translating it into standardized workflows.
- Improves consistency of workflows by ensuring all GIS professionals not only easily understand the work they need to do but also perform that work in the same way. This reduces error and increases the quality of the output.
Do workflows need to be rebuilt for every project?
No. ArcGIS Topographic Mapping provides out-of-the-box workflows for data editing, quality control, and cartography. These workflows are pre-configured to use data standards, cartographic rules, and generalization models, thus improving repeatability and reducing manual rework.
How does this extend beyond the foundational editing and visualization capabilities of ArcGIS Pro and ArcGIS Enterprise?
Unlike ad-hoc GIS workflows, ArcGIS Topographic Mapping focuses on standards-based production by capturing organizational rules, specifications, and domain knowledge and applying them consistently across data collection, cartography, and multiscale production. These pre-configurations are built into the product to enable mapping agencies to quickly generate data and map products that meet organization or industry-specific requirements.
Data Related
How does ArcGIS Topographic Mapping improve data consistency across teams?
Topographic Mapping provides standardized feature templates, validation rules, schemas, and editing tools that guide GIS professionals during data capture. This ensures that best-scale data is created consistently regardless of who performs the work.
Does quality control happen during or after data capture?
Quality control workflows are integrated directly into the data capture process. This allows errors/issues to be identified and corrected early rather than discovered downstream, during cartography or generalization.
Can organizations enforce their own data specifications and standards?
Yes. ArcGIS Topographic Mapping allows organizations to configure and enforce their own schemas, validation rules, and production standards, ensuring output meets internal and external regulatory requirements.
Cartography Related
Can ArcGIS Topographic Mapping reduce manual cartographic effort, especially for organizations that produce a high volume of maps?
Yes. Topographic Mapping enables specification-driven cartography by using standardized map templates and cartographic rules. Since these are pre-configured, it allows many finishing steps to be automated and consistently applied across products.
My organization has many cartographers. Can they still produce consistent outputs?
Yes. By centralizing cartographic rules and templates, ArcGIS Topographic Mapping ensures your map outputs are consistent, regardless of who performs the work. This greatly minimizes variability in how different cartographers generate the outputs.
Is cartographic automation all-or-nothing?
No. Organizations can automate repetitive finishing steps while retaining manual control where needed. That way, your teams can balance efficiency with cartographic judgment.
Generalization Related
How does ArcGIS Topographic Mapping support multiscale production?
It uses pre-configured generalization rules and models to generate scale-appropriate data and cartographic products from a single best-scale database within a standardized workflow.
Does generalization need to be reconfigured for every project?
No. Once generalization rules and models are configured, they can be reused across projects and areas. This gives you the ability to generate consistent multiscale outputs and reduce manual rework.
Can generalization be integrated into an automated production workflow?
Yes. Generalization is designed to be part of an end-to-end production workflow, from data capture to cartographic output, that supports automation, repeatability, and enterprise-scale production.
Enterprise & Scaling Related
How does ArcGIS Topographic Mapping scale beyond desktop workflows?
ArcGIS Pro supports hands-on, desktop-based production while ArcGIS Enterprise enables organization-wide workflow orchestration, job management, and automated map production. Together, ArcGIS Pro and ArcGIS Enterprise allow organizations to scale topographic production across teams.
Can ArcGIS Topographic Mapping support on-demand or self-service map production?
Yes. ArcGIS Topographic Mapping Enterprise includes capabilities that support on-demand product generation using the same standardized rules and templates as ArcGIS Pro workflows.
