I have a script that has three for loops that are nested within each other. Top two just do a little housework but the deepest does the following:
- Builds paths to CSVs
- Reads those CSVs into pandas
- Deletes the working GDB if it exists
- Recreates that GDB
- Makes a Closest Facility Analysis Layer
- Converts the incidents and facilities dataframe into XY Tables
- Loads those XY Tables into the incidents and facilities sublayers of the Closest Facility Analysis Layer
- Solves for routes
- Exports those routes as a CSV
The first run of the loop is fine, but I get into trouble when deleting the working GDB. I've tried probably two dozen different ways to get around the lock, but nothing seems to do anything:
- I've created variables for the closest facility layers, incident/facility XY tables, the results of the solve and the GDB itself and tried to use python's del to delete the object from the interpreter. None of that seems to do anything all the lock files are still there.
- I've tried arcpy.ClearWorkspaceCache_management(), that doesn't do anything all the lock files remain.
- I've tried just adding waits in a couple places. Didnt work.
- I've tried a function that uses while time.time() to wait for the lock to be released on its own thinking I'm just rushing the lock release. After 5m the locks are still there.
- I've tired shutil.delete instead of arcpy.Delete_management(). That does nothing.
- I've tried splitting the entire thing into a series of functions hoping the different namespaces will fix the issue. That does nothing.
- I've tried python's garbage collector built in. That does nothing.
- I've replicated the script from scratch trying to figure out when are where the locks occur from and which one is causing the issue. That script works just fine, no errors when I'm functionally doing the same thing.
I'm just absolutely at my wits end on trying unsuccessfully to manage these locks. Nothing works and all the ESRI resources do not do what ESRI says they are supposed to do or they explain them so poorly that it doesn't get through my thick skull.
So, the locks that exist at the end of the first loop are:
- _gdb.sr.lock
- Closest Facility Analysis Sublayers
- Barriers.sr.lock
- CFRoutes.sr.lock
- Facilities.sr.lock
- Facilities.rd.lock
- Incidents.sr.lock
- Incidents.rd.lock
- PolygonBarriers.sr.lock
- PolylineBarriers.sr.lock
How am I supposed to remove these?
# Libraries
import pandas as pd
import numpy as np
import arcpy
import time
import shutil
import os
import gc
pd.options.display.max_columns = None
# CONFIG
mce_list = [
# 'ADV HEALTH',
# 'ALLCARE',
# 'CHA',
# 'CPCCO',
# 'EOCCO',
# 'HEALTHSHARE',
# 'IHN',
# 'JCC',
'PSCS-CG',
'PSCS-CO',
'PSCS-LN',
'PSCS-MP',
# 'TRILLIUM-SW',
# 'TRILLIUM-TC',
# 'UHA',
# 'YCCO'
Plan_to_services = {
'CCOA' : ['Physical', 'Behavioral', 'Dental'],
'CCOB' : ['Physical', 'Behavioral'],
'CCOE' : ['Behavioral'],
'CCOF' : ['Dental'],
'CCOG' : ['Behavioral', 'Dental'],
Specialty_to_service = {
# 'Allergy and Immunology' : 'Physical',
# 'Cardiology': 'Physical',
# 'Dermatology': 'Physical',
# 'Durable Medical Equipment': 'Physical',
# 'Endocrinology': 'Physical',
# 'ENT or Otolaryngology': 'Physical',
# 'Gastroenterology': 'Physical',
# 'Gynecology': 'Physical',
# 'Hematology': 'Physical',
'Hospital': 'Physical',
'Mental Health Provider': 'Behavioral', #Behavioral
'Mental Health Residential': 'Behavioral', #Behavioral
'Methadone Clinic': 'Physical',
'Nephrology': 'Physical',
'Neurology': 'Physical',
'Obstetrics': 'Physical',
'Occupational Therapy': 'Physical',
'Oncology Medical': 'Physical',
'Oncology Radiation': 'Physical',
'Ophthalmology': 'Physical',
'Optometry': 'Physical',
'Pharmacy': 'Physical',
'Physical Therapy': 'Physical',
'Podiatry': 'Physical',
'Primary Care': 'Physical',
'Primary Care Dentistry': 'Dental', #Dental
'Psychiatry': 'Physical',
'Psychology': 'Behavioral', #Behavioral
'Pulmonology': 'Physical',
'Reproductive Endocrinology': 'Physical',
'Rheumatology': 'Physical',
'Skilled Nursing Facility': 'Physical',
'Speech Language Pathology': 'Physical',
'Substance Use Disorder Provider': 'Physical',
'Substance Use Disorder Residential': 'Physical',
'Urology': 'Physical'
def extract_cco_plan(filename):
for plan in Plan_to_services:
if plan in filename:
return plan
raise ValueError(f'CCO Plan not found in {filename}')
def get_specialties_for_plan(plan):
return[
spec for spec, svc in Specialty_to_service.items()
if svc in Plan_to_services[plan]
nds = r'{path-to-streetmappremium}'
coordinate_system = (
'GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",'
'SPHEROID["WGS_1984",6378137.0,298.257223563]],'
'PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]];'
'-400 -400 1000000000;-100000 10000;-100000 10000;'
'8.98315284119521E-09;0.001;0.001;IsHighPrecision'
travel_modes = arcpy.na.GetTravelModes(nds)
travel_mode_miles = arcpy.na.TravelMode(travel_modes['Driving Time'])
travel_mode_miles.distanceAttributeName = 'Miles'
field_mappings_locations = (
"Name Address #;CurbApproach # 0;Attr_Minutes # 0;"
"Attr_TimeAt1KPH # 0;Attr_TravelTime # 0;"
"Attr_TruckMinutes # 0;Attr_TruckTravelTime # 0;"
"Attr_WalkTime # 0;Attr_Kilometers # 0;"
"Attr_Miles # 0"
# PATHS
path = os.getcwd()
print('Current Working Directory:', path)
staging = os.path.join(path, 'Staging Data')
os.makedirs(staging, exist_ok=True)
na_gdb_path = os.path.join(path, 'Network Adequacy.gdb')
closest_facility_path = os.path.join(na_gdb_path, 'Closest Facility')
routes = os.path.join(closest_facility_path, 'Routes')
incidents = os.path.join(closest_facility_path, 'Incidents')
facilities = os.path.join(closest_facility_path, 'Facilities')
routes_gdb = os.path.join(na_gdb_path, 'Routes_Export')
incidents_gdb = os.path.join(na_gdb_path, 'Incidents_Export')
facilities_gdb = os.path.join(na_gdb_path, 'Facilities_Export')
routes_csv = os.path.join(staging, 'Routes_ExportTable.csv')
incidents_csv = os.path.join(staging, 'Incidents_ExportTable.csv')
facilities_csv = os.path.join(staging, 'Facilities_ExportTable.csv')
# HELPER FUNCTIONS
def safe_delete_csv(path):
if os.path.exists(path):
os.remove(path)
def export_gdb_to_csv(in_table, gdb_table, csv_path):
"""Lock-safe export: FeatureClass/Table → GDB → temp CSV → rename"""
if arcpy.Exists(gdb_table):
arcpy.Delete_management(gdb_table)
arcpy.conversion.ExportTable(in_table, gdb_table)
temp_csv = csv_path.replace('.csv', '_tmp.csv')
safe_delete_csv(temp_csv)
tbl = arcpy.conversion.TableToTable(
gdb_table,
os.path.dirname(csv_path),
os.path.basename(temp_csv)
safe_delete_csv(csv_path)
os.rename(temp_csv, csv_path)
del tbl
# MAIN LOOP
subccos = ['A', 'B', 'E', 'F', 'G']
for subcco in subccos:
for mce in mce_list:
members_csv = os.path.join(path, f'Q3 2025/01 Members Output Adult CCO Plan/{mce}_CCO{subcco}_AdultMembers.csv')
cco_plan = extract_cco_plan(members_csv)
spec_list = get_specialties_for_plan(cco_plan)
print(f'\nMCE: {mce}')
print(f'CCO Plan: {cco_plan}')
print(f'Specialties used: {spec_list}')
for spec in spec_list:
print(f'\nProcessing {mce} - {spec}')
staging,
f"Routes_ExportTable_{spec.replace('-', '_')}_{mce.replace('-', '_')}.csv")
facilities_csv_in = os.path.join(
path, f'Q3 2025/02 Facilities Output Adult/{mce}_{spec}_Facilities.csv'
output_csv = os.path.join(
path, f'Q3 2025/03 Routing Output Adult/{mce}_{spec}_CCO{subcco}_Routes.csv'
members_df = pd.read_csv(members_csv, dtype=str)
facilities_df = pd.read_csv(facilities_csv_in, dtype=str)
if 'Age_Group' not in facilities_df.columns:
print("Warning: Age_Group column not found in facility data. Skipping Age_Group.")
print(f'routing {len(members_df)} incidents to {len(facilities_df)} facilities...')
if len(facilities_df) == 0:
print('No facilities found – writing empty output.')
pd.DataFrame({
'MCE_Name': mce,
'Specialty': spec,
'Incident_Match_ID': members_df['Incident_Match_ID'],
'Facility_Match_ID': np.nan,
'Driving_Minutes': np.nan,
'Driving_Miles': np.nan
}).to_csv(output_csv, index=False)
if arcpy.Exists(na_gdb_path):
try:
del na_gdb
except Exception as e:
print(e)
arcpy.Delete_management(na_gdb_path)
na_gdb = arcpy.management.CreateFileGDB(path, 'Network Adequacy.gdb')
arcpy.env.workspace = na_gdb_path
print('Making a new Closest Facility layer...')
closest_facility = arcpy.na.MakeClosestFacilityAnalysisLayer(
nds, closest_facility_path, travel_mode_miles
incidents_xy_path = os.path.join(na_gdb_path, 'Incidents_XY')
facilities_xy_path = os.path.join(na_gdb_path, 'Facilities_XY')
print('Building Incidents XY Table')
incidents_xy = arcpy.management.XYTableToPoint(
members_csv, incidents_xy_path, 'X', 'Y', None, coordinate_system
print('Building Facilities XY Table')
facilities_xy = arcpy.management.XYTableToPoint(
facilities_csv_in, facilities_xy_path, 'X', 'Y', None, coordinate_system
print('Adding Incidents XY Table to Analysis Layer')
arcpy.na.AddLocations(closest_facility_path, 'Incidents', incidents_xy_path)
print('Adding Facilities XY Table to Analysis Layer')
arcpy.na.AddLocations(closest_facility_path, 'Facilities', facilities_xy_path)
print('Solving')
solve = arcpy.na.Solve(closest_facility_path, 'SKIP', 'TERMINATE')
# EXPORTS (SAFE)
print('Exporting Routes / Incidents / Facilities')
if arcpy.Exists(routes_csv):
arcpy.Delete_management(routes_csv)
export_gdb_to_csv(routes, routes_gdb, routes_csv)
export_gdb_to_csv(incidents, incidents_gdb, incidents_csv)
export_gdb_to_csv(facilities, facilities_gdb, facilities_csv)
try:
del closest_facility
del incidents_xy
del facilities_xy
del solve
del na_gdb
print(e)
