Is there a way to easily delete test data entries/records submitted to the Request Management Center?
It is easiest to do in ArcGIS Pro. If all the records are test records then Truncate Table will clear everything and reset the ObjectID to one. Otherwise, in ArcGIS Pro you can open the attribute tables, select the records that are tests, and delete the rows. You will need to do this on the root feature layers that you added test records to. You do not have to mess with the views because the changes will propagate up from the root feature layers.
Ah yes, thanks for the reminder about that! Worked perfectly.
