We are using ArcGIS JavaScript API 4.32.0 with a React (Vite) application and the GeoEnrichment createReport service to generate Demographic Reports.
- Previously, the report generation and download worked using a static API Key, but recently (Last Week) we observed that the service now requires token-based authentication with expiration, meaning a new token must be generated periodically instead of using the API key directly.
- Below is the error message . we have confirm that token is still valid, beacuse we are able to featch the aviablable demographic list using the status API key :
"error" : {
"code" : 498,
"message" : "Invalid token. (code = 498). [].",
"details" : [ ]
}- Additionally, we noticed some changes in the report response/PDF format, which initially caused issues opening the downloaded report in different PDF clients.
Could you please confirm:
If there has been a recent change in authentication requirements for the GeoEnrichment service?
Whether API keys are no longer supported for report downloads and OAuth/token authentication is now required?
If there were recent updates to the report generation or response format?
We are currently running this with ArcGIS JS API 4.32.0 in a React (Vite) environment.
Any clarification or documentation on these changes would be appreciated.
