I am trying to export a map to an interactive PDF. Most of the layers making up the PDF are polygon or point shapefiles that have been labeled normally as a feature layer. However, when I go to export the PDF, each shapefile shows as a separate layer that can be toggled on and off in the PDF, but all of the labels have been combined as one “Labels” layer in the PDF. Is it possible to configure the shapefiles and/or export parameters such that the labels of each shapefile can be individually toggled on and off with each shapefile layer in the PDF? Thanks for any help in advance.
