At version 4.34, using projectOperator on geometries with z values fixes all its z values to 0!
Anyone has a workaround for this ?
Hi @ChristopheSuter ,
Do both spatial references have the same vertical coordinate system and only differ in their horizontal coordinate system? There is a known limitation where vertical coordinate system projections are not currently supported. This should be better documented when version 5.0 comes out next week.
@ChristopheSuter can you provide a repro sample?
Hi Sage,
No, both spatialReferences have same vcsWkids equal to null, but thanks for the upcoming info
Yes but it does not help, since it works correctly: https://codepen.io/christophesuter/pen/WbxVEvq since creating the geometry from its json solves it. Difficult for us to see why it works with a new instance of the geometryI have adapted my projection method like this .. but it is still a workaround i think
@ChristopheSutergotcha. How are your non-new instance geometries being created when they have the z-problem?
If converting them to JSON is correcting the problem then it's possible there is some sort of issue with the non-JSON geometry instances. If you continue to have issues, or run into convert/revert performance issues, then I'd encourage you to open a support ticket so we can take a deeper look.
Found some strange way to correct the problem, maybe it can help. I am using a polylineGeometry returned by the sketchViewModel with :
in a 2d mapview. Then i use this geometry (that is in EPSG:2056, and has all of its z values to 0 that seems logic) to query elevation on Esri's elevation service (that is in EPSG:3857), so i use the projectOperator to reproject my geometry and then query Elevation on esri's elevationLayer. Everything ok, elevation z fixed and x/y in EPSG:3857.Then I have to reconvert it to EPSG:2056 -> sets all the z to 0.So I modified the sketchViewModel property (removed hasZ):
