After logging into AGOL with ArcGIS Pro on a system, it remembers my login when I open Pro after that. Which is great as it would be annoying to have to login every time. But, I tend to work on multiple systems concurrently between running processing, reviewing data and doing development. So occasionally I accidentally try to login on more then 3 systems at once which exceeds my licensing limit. When this happens, the 4th system will not login automatically and brings up the login window. First, it doesn't indicate that I logged in on too many systems. It just brings up the login window so I don't always know exactly why it's doing this. It would be helpful if it told me the reason it wasn't automatically logged in. But more importantly, it seems to wipe the cached login. If I log off of one of the other systems so that I have room to login again, I can't just close the login window and open Pro again to use that available license. I have to now login again and go through the MFA procedure. Can Pro remember my cached login details and re-use those like it normally does in this situation as well?
