Greetings All:
I am teaching a field methods course and walked the participants through creating a Survey123 in the web designer including a calculated value that was a very simple example: Tree height (ft) - then the calculated value in the next field calculated that to be in (m).
All was well when they filled out this survey using the web browser and I've done this many times in the past.
However this week I wanted them to also try the survey with the Survey123 app. I tried it at least 10 times, and so did the participants, but none of them nor me could get the calculated valued to work in the app. The app does not calculate the value--it shows as a field that you have to input. Inputting the value in meters defeats the whole purpose of the calculated value!
The app is updated and is the latest version.
This is something that is very simple and should just WORK. Thanks for any nuggets of wisdom that you might have.
