Hi All,
Is it possible to remove just 0 labels from my line chart that is based on time/date. I want to total count label to be visible but remove 0's from the chart as well as the same between the different peaks.
What happens if you do a filter for those values (where the value does not equal 0)? Does it truncate your chart in a way that does not look good?
Thanks @AdrianWelsh No change unfortunately, is it because it's a date field?
Possibly so. Can you change the value of the 0 to a null value, therefore nothing should show up?
Did that nothing changed. To explain further the 0 values don't exist within the data, that's where I am having trouble filtering it out.
