I wasn't sure if this question should be posted here or in the "Geodatabase Questions" section but the issue isn't really (imo) a database issue, but with how ArcGIS Pro displays the view.
So the problem is that the view(s) in question have duplicate OBJECTIDs, which is intended. I am getting the attribute tables of these views to load by generating a column of UIDs by using:
cast(rownum as number(38)) as MYUID
This is done in the first column in my views, which each looking something like:
create or replace view MYVIEW(MYUID, COL1, COL2,...)
as
select(cast(rownum as number(38)) as MYUID, VAR1, VAR2,...)
The UIDs are always the first column, and I've tried using various alias for the UID column (such as OBJECTID, ROWNUMID, etc.), but it's a hit or miss whether or not ArcGIS Pro will auto-select it for use as the "default" UID field. If it does, the attribute table loads, if it doesn't, it fails to load and then I need to go in and manually set the UID field to it. This is fine, but creates extra work every time the view is loaded into a new project.
Is there a way to somehow get ArcGIS Pro to auto-select that first column as UID every time so whenever someone creates a new project using that view they won't get the error and then have to manually go set UID?
