The geodatabase modeling and design requirements survey closes tomorrow (Wed) August 31st at 11:59pm Eastern US time. Thanks to those who've already participated. It's a user-driven survey I helped create in support of the Geodatabase Modeling and Design Special Interest Group (SIG) for Esri's 2011 International User Conference.I'd love to see more International representation. Most responses are from the US. Qualitative answers (text entries) are more valuable than quantitative ones (check boxes, etc). Please mention specific use cases and anything that would help in your daily work. Skip whatever isn't relevant. The survey isn't just for experts. It's for anyone who designs geodatabases. Of particular interest to me in designing the survey was integration of Enterprise GDB Design with Relational Database Design and the rest of Enterprise IT.A summary of survey results will be posted to my blog, http://SpatialDba.com, by October 31st.Direct survey link:http://spatialdba.com/limesurvey/index.php?sid=72916&lang=enA review of the 2011 SIG event can be found below. Hope to do another in 2012:A View of the Geodatabase Modeling and Design SIG Event at Esri�??s 2011 International User Conferencehttp://spatialdba.com/?p=104
Hi Timothy,To be clear, you need to have a software license of MS Visio 2003/2007. You would create your own UML model (as a Visio diagram) that defines the schema of a geodatabase (or you can edit an existing data model). You can get the ArcInfo UML template file from the first link in my previous post:Building Geodatabases with CASE Tools(under the Support Files section > ArcInfo UML model template)When you've finished your Visio diagram, you can import it into an empty geodatabase in ArcCatalog with the Schema Wizard tool - which is available in ArcCatalog, from the Customize dialog > Commands tab > Case Tools category. You will have to add the Schema Wizard tool to the UI.Hope this helps,
What is the hyperlink that allows me to specifically download CASE Tools for use in Visio 2003 with ArcGIS 9.3.1?
Hi Timothy,Here are some resources to get you started on working UML data models and ArcGIS:Building Geodatabases with CASE ToolsA note about the use of UML for geodatabase designUsing CASE tools in ArcGIS 10 blog postHope this helps,
