I am not sure if it is a BUG or something else. I published a survey through Survey123 Connect on to ArcGIS online. I have the latest version of Connect, and it will not allow multiple submissions under the Survey123 web. I tried republishing and it still will not open up multiple submissions.
Could you please elaborate on "will not open up multiple submissions"?
Also, as per the warning, you should disable either the Inbox or the Sent folder:
So if I am understanding correctly, everything is working other than the ability to submit edits for an existing record? If that is the case, there are two possible settings you can configure.
This first, and easiest, setting is cut off in your screen shots above. It is in Connect on the Options tab:
The second is buried in Portal (I'd recommend using Connect before trying this):
Also, as I mentioned above, you should heed the warning in Connect and disable either the "Inbox" or the "Sent" folder (if not done so already).
I think it could be related to your use of mode=edit. You're talking about adding new records, but mode=edit appears to only allow editing of existing records in the web form. Check out The Basics section of the link below.
Survey123 Tricks of the Trade: Editing records in ... - Esri Community
You might need to create 2 links, one for editing an existing record and one for creating new records. Keep in mind if you are creating a link to existing records and there are multiple records for a feature (let's say these are inspection records of a power pole) you will need to create an individual link for each existing record. You'd need to use arcade, or some other language to iterate through a list of globalids for the existing records and create a list of links to open each existing record as needed.
